--- TLP 0.4 --------------------------------------------
+++ Configured Settings: /etc/default/tlp
TLP_ENABLE=1
DISK_IDLE_SECS_ON_AC=0
DISK_IDLE_SECS_ON_BAT=2
MAX_LOST_WORK_SECS_ON_AC=15
MAX_LOST_WORK_SECS_ON_BAT=60
SCHED_POWERSAVE_ON_AC=0
SCHED_POWERSAVE_ON_BAT=1
NMI_WATCHDOG=0
DISK_DEVICES="sda sdb"
DISK_APM_LEVEL_ON_AC="254 254"
DISK_APM_LEVEL_ON_BAT="128 128"
SATA_LINKPWR_ON_AC=max_performance
SATA_LINKPWR_ON_BAT=min_power
PCIE_ASPM_ON_AC=performance
PCIE_ASPM_ON_BAT=powersave
RADEON_POWER_PROFILE_ON_AC=high
RADEON_POWER_PROFILE_ON_BAT=low
RADEON_DPM_STATE_ON_AC=performance
RADEON_DPM_STATE_ON_BAT=battery
RADEON_DPM_PERF_LEVEL_ON_AC=auto
RADEON_DPM_PERF_LEVEL_ON_BAT=auto
WIFI_PWR_ON_AC=1
WIFI_PWR_ON_BAT=5
WOL_DISABLE=Y
SOUND_POWER_SAVE=1
SOUND_POWER_SAVE_CONTROLLER=Y
BAY_POWEROFF_ON_BAT=0
BAY_DEVICE="sr0"
RUNTIME_PM_ON_AC=on
RUNTIME_PM_ON_BAT=auto
RUNTIME_PM_ALL=0
USB_AUTOSUSPEND=1
USB_BLACKLIST_WWAN=1
RESTORE_DEVICE_STATE_ON_STARTUP=0
START_CHARGE_THRESH_BAT0=60
STOP_CHARGE_THRESH_BAT0=90
+++ System Info
System = LENOVO ThinkPad X61 Tablet 7763WDK
BIOS = 7SET39WW (1.25 )
Release = Linux Mint 15 Olivia
Kernel = 3.8.0-26-generic x86_64
/proc/cmdline = BOOT_IMAGE=/vmlinuz-3.8.0-26-generic root=UUID=cc2d015e-c411-49d5-a239-53a39509a611 ro quiet splash vt.handoff=7
+++ System Status
TLP power save = enabled
power source = ac
+++ Processor
CPU Model = Intel(R) Core(TM)2 Duo CPU L7700 @ 1.80GHz
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver = acpi-cpufreq
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor = ondemand
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq = 800000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq = 1801000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies = 1801000 1800000 1200000 800000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_driver = acpi-cpufreq
/sys/devices/system/cpu/cpu1/cpufreq/scaling_governor = ondemand
/sys/devices/system/cpu/cpu1/cpufreq/scaling_min_freq = 800000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_max_freq = 1801000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_available_frequencies = 1801000 1800000 1200000 800000 [kHz]
/sys/devices/system/cpu/cpufreq/boost = 1
/proc/sys/kernel/nmi_watchdog = 0
+++ Undervolting
PHC kernel not available.
+++ Temperatures
/proc/acpi/ibm/thermal = 46 58 58 43 30 -128 29 -128 44 41 -128 -128 -128 -128 -128 -128 [°C]
/proc/acpi/ibm/fan = 2894 [/min]
+++ File System
/proc/sys/vm/laptop_mode = 0
/proc/sys/vm/dirty_writeback_centisecs = 1500
/proc/sys/vm/dirty_expire_centisecs = 1500
/proc/sys/vm/dirty_ratio = 20
/proc/sys/vm/dirty_background_ratio = 10
/proc/sys/fs/xfs/age_buffer_centisecs = (not available)
/proc/sys/fs/xfs/xfssyncd_centisecs = (not available)
/proc/sys/fs/xfs/xfsbufd_centisecs = (not available)
+++ Storage Devices
/dev/sda:
Model = SAMSUNG 470 Series SSD
Firmware = AXM09B1Q
APM Level = none/disabled
Status = active/idle
TRIM = supported
scheduler = deadline
/dev/sdb:
Model = SanDisk SSD U100 32GB
Firmware = KM.10.00
Status = unknown
TRIM = supported
+++ SATA Aggressive Link Power Management
/sys/class/scsi_host/host0/link_power_management_policy = max_performance
/sys/class/scsi_host/host1/link_power_management_policy = max_performance
/sys/class/scsi_host/host2/link_power_management_policy = max_performance
+++ PCIe Active State Power Management
/sys/module/pcie_aspm/parameters/policy = default (using bios preferences)
+++ Intel Graphics
/sys/module/i915/parameters/powersave = 1 (enabled)
/sys/module/i915/parameters/i915_enable_rc6 = -1 (use per-chip default)
/sys/module/i915/parameters/i915_enable_fbc = -1 (use per-chip default)
/sys/module/i915/parameters/lvds_downclock = 0 (disabled)
/sys/module/i915/parameters/semaphores = -1 (use per-chip default)
+++ Wireless
bluetooth = off (software)
wifi = on
wwan = on
wlan0(iwlwifi): power management = off
+++ Audio
/sys/module/snd_hda_intel/parameters/power_save = 1
/sys/module/snd_hda_intel/parameters/power_save_controller = Y
+++ ThinkPad Extended Battery Functions
tp-smapi = active
tpacpi-bat = inactive (unsupported hardware)
+++ ThinkPad Battery Status (Main)
/sys/devices/platform/smapi/BAT0/manufacturer = SANYO
/sys/devices/platform/smapi/BAT0/model = 42T4661
/sys/devices/platform/smapi/BAT0/manufacture_date = 2009-12-28
/sys/devices/platform/smapi/BAT0/first_use_date = 2010-02-18
/sys/devices/platform/smapi/BAT0/cycle_count = 196
/sys/devices/platform/smapi/BAT0/design_capacity = 66240 [mWh]
/sys/devices/platform/smapi/BAT0/last_full_capacity = 55430 [mWh]
/sys/devices/platform/smapi/BAT0/remaining_capacity = 48840 [mWh]
/sys/devices/platform/smapi/BAT0/remaining_percent = 89 [%]
/sys/devices/platform/smapi/BAT0/remaining_running_time_now = 24506 [min]
/sys/devices/platform/smapi/BAT0/remaining_charging_time = not_charging [min]
/sys/devices/platform/smapi/BAT0/power_now = 0 [mW]
/sys/devices/platform/smapi/BAT0/power_avg = 0 [mW]
/sys/devices/platform/smapi/BAT0/start_charge_thresh = 60 [%]
/sys/devices/platform/smapi/BAT0/stop_charge_thresh = 90 [%]
/sys/devices/platform/smapi/BAT0/force_discharge = 0
+++ Runtime Power Management
/sys/bus/pci/devices/0000:00:00.0/power/control = on (0x060000 Host bridge)
/sys/bus/pci/devices/0000:00:02.0/power/control = on (0x030000 VGA compatible controller)
/sys/bus/pci/devices/0000:00:02.1/power/control = on (0x038000 Display controller)
/sys/bus/pci/devices/0000:00:19.0/power/control = on (0x020000 Ethernet controller)
/sys/bus/pci/devices/0000:00:1a.0/power/control = on (0x0c0300 USB controller)
/sys/bus/pci/devices/0000:00:1a.1/power/control = on (0x0c0300 USB controller)
/sys/bus/pci/devices/0000:00:1a.7/power/control = on (0x0c0320 USB controller)
/sys/bus/pci/devices/0000:00:1b.0/power/control = on (0x040300 Audio device)
/sys/bus/pci/devices/0000:00:1c.0/power/control = on (0x060400 PCI bridge)
/sys/bus/pci/devices/0000:00:1c.1/power/control = on (0x060400 PCI bridge)
/sys/bus/pci/devices/0000:00:1d.0/power/control = on (0x0c0300 USB controller)
/sys/bus/pci/devices/0000:00:1d.1/power/control = on (0x0c0300 USB controller)
/sys/bus/pci/devices/0000:00:1d.7/power/control = on (0x0c0320 USB controller)
/sys/bus/pci/devices/0000:00:1e.0/power/control = on (0x060401 PCI bridge)
/sys/bus/pci/devices/0000:00:1f.0/power/control = on (0x060100 ISA bridge)
/sys/bus/pci/devices/0000:00:1f.2/power/control = on (0x010601 SATA controller)
/sys/bus/pci/devices/0000:00:1f.3/power/control = on (0x0c0500 SMBus)
/sys/bus/pci/devices/0000:02:00.0/power/control = on (0x048000 Multimedia controller)
/sys/bus/pci/devices/0000:03:00.0/power/control = on (0x028000 Network controller)
/sys/bus/pci/devices/0000:05:00.0/power/control = on (0x060700 CardBus bridge)
/sys/bus/pci/devices/0000:05:00.2/power/control = on (0x080500 SD Host controller)
/sys/bus/pci/devices/0000:06:00.0/power/control = on (0x0c0310 USB controller)
+++ USB
tlp usb autosuspend = enabled
tlp usb blacklist = (not configured)
Bus 001 Device 003 ID 0781:5580 control = auto, autosuspend_delay_ms = 2000 -- SanDisk Corp. (usb-storage)
Bus 007 Device 003 ID 0af0:7011 control = auto, autosuspend_delay_ms = 2000 -- Option (hso)
Bus 001 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 2.0 root hub (hub)
Bus 002 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 2.0 root hub (hub)
Bus 003 Device 001 ID 1d6b:0001 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 1.1 root hub (hub)
Bus 004 Device 001 ID 1d6b:0001 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 1.1 root hub (hub)
Bus 005 Device 001 ID 1d6b:0001 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 1.1 root hub (hub)
Bus 006 Device 001 ID 1d6b:0001 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 1.1 root hub (hub)
Bus 007 Device 001 ID 1d6b:0001 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 1.1 root hub (hub)
+++ Suggestions
* Install ethtool to disable Wake on LAN
* Install smartmontools for disk drive health info
